Powersteering fluid?
  • Powersteering fluid?
    What Powersteering fluid are you using? As I always do I tried searching and couldn't come up with anything.
    @slowprogress
    Bmws use ATF in power steering systems.
      I use pentosin CHF 7.1 but switched to m30b35 pump and using stock e30 m3 rack.
        Hi, JZM3,
        I use synthetic ATF in the PS. either Red Line or Mobil 1 or whatever they call it. I've read that using synthetic ATF will prolong the life if the PS system by maybe a factor of 2.
        Larry
