Gustave's Ignition Wire Bracket Help
  • Gustave's Ignition Wire Bracket Help
    Does anyone know where I can order the little black wire holders (says T-8 on them)? I need to replace a couple of them that have broke over the years.
    Mike
    So I spent the last hour (okay, maybe 10 minutes, but it felt like an hour!) searching google and finally found a part/part number. If anyone else needs replacement ones, they are:
    MSD Ignition 8842 Plug Wire Spacer
      You can also get them from McMaster-Carr:
      http://www.mcmaster.com/#pipe-routing-clamps
      (scroll down to the "Double-line snap-in plastic clamps")
        Thanks. I tried looking there before and couldn't find them. That's where I will probably order these.
        Mike
