Anyone running these injectors from Five-O Motorsport - High Z
  • Anyone running these injectors from Five-O Motorsport - High Z
    Like the title says, anyone using these?
    http://www.fiveomotorsport.com/black...s-us-euro-long
    I plan to order a set soon. Bruce at Five-O assures me that they will fit the S14. I've wanted to try running high Z injectors for a while now. ECU settings are more straightforward than with the low Z, taking out some of the guess work. These should have a shorter dead time and better spray pattern than the injectors I'm running now. I'm planning to order these in a couple weeks and will report back after I've installed them. I am running a fully programmable Megasquirt ECU, so I don't have to stick with stock spec injectors.
    Any thoughts?
    Brad
    Last edited by indie_wannabe; 08-13-2013, 03:38 AM. Reason: Switched up high z and low z in a couple places
    I'm running 52lb versions. No issues.
    Sport Evo No.47
    My Sport Evo Restoration
      Are you using the "wireless" plug adapter or the adapter with a pig tale?
        I built my own loom complete as part of a Motec install.
        Sport Evo No.47
