While this may be common knowledge to most here in regards to swapping in an all aluminum radiator, I was very pleasantly surprised when I was on the highway yesterday and my temps didn't creep a little past half like they normally would do. IIRC the temps only got in between the first and middle mark.
I'm not sure if the radiator is just really a lot better than stock or if my OEM one was messed up or clogged (I replaced it since it was leaking), but I'm thoroughly enjoying the fact that if I do have a problem, I should have plenty of time to see it while driving rather than always being a needle over half.
I read that a needle over half is normal though, do you guys normally drive like this?
The radiator I ended up getting was on eBay: http://www.ebay.com/itm/290792109516 I thought I was getting the Mishimoto but was comparing several and accidentally ended up having this one in my cart with some other items. Two small modifications were needed, the small brackets where the bottom of the radiator sits needed to be ground down a tiny bit, and the fan shroud needed some material taken away for the new radiator's drain plug (bottom center). If I were to do it again, I would get the Mishimoto just because of the warranty. So far, this one has been great, but time will tell.
On a side note, I also got the HPS silicone hose set and I'm impressed with the kit as a whole. It's nice getting the clamps with it not for an extra charge: http://www.ebay.com/itm/230889142113
