which cooling system hoses are needed?
    good points.
    kevin, ill be sure to change the expansion tank cap.
    are you sure a 90/10 mixture is ok? I live in California, so it never gets very cold, or very hot. i've typically used about a 50/50 mixture for my other cars. is the s14 different? someone also mentioned to me to use water wetter with it. any thoughts on this? What exactly does it do?
      I will be doing this sometime in the future as well...do you need to full the hoses with coolant as you attach them to prevent air pockets? Or can you just clamp em up, fill the radiator and resivoir and start the car? Thanks
        AlpineRunner,
        The system will self bleed itself of air bubbles. I believe you connect everything up, fill it with coolant, and then let it run with the heater on in the car, and the reservoir cap off. The bubbles should work their way out.
        Someone please correct me if I'm wrong, since this is what i'll be doing!
          Originally posted by marsfire
          AlpineRunner,
          You're right, that's how I did mine. Oh make sure you get the tool to get the water pump nut off, its a biotch if you don't.
            where to get the water pump nut tool?
            hey KauzE30M3,
            Where do I get this tool to remove the water pump nut??
              I believe you can get it at the dealership. From what I hear there is a bike tool that can do the trick, but ask around for that. When I changed out my water pump I didn't have the tool. We took the pump out w/ the fan still attached. We used a strap wrench and a shit load of muscle. That thing tightens itself up through the years since it's reverse thread. The tool would have made it easier. Good luck with everything.
              Neil
                Re: where to get the water pump nut tool?
                hey KauzE30M3,
                allow me to save you from the wrath of Mr Searchy
                http://www.s14.net/forums/showthread...&threadid=2411
                :cool:
                • #23
                  Viola! Magic!
                  http://www.s14.net/forums/search.php
