Help, oil seepage from front of head....
  • Help, oil seepage from front of head....
    I seem to be having some moderate oil seepage from an odd location on the front of the cylinder head. Let me see if I can accurately describe the source of the leak. Standing on the right side of the car looking at the front of the head. There is a round cap, approximately 3.5 inches in diameter. This cap is somehow fastened to the lower front head. Also, this cap has a 2 inch slot casted into it which I assume is how the cap is tightened or losened.
    Note, this is not the cap that covers the end of the intake cam. This mystery cap is down lower on the front of the head. Anyone have an idea what this cap is and how to address my oil seepage issue since there is no obvious way to remove and reseal this cap?
    Thanks so much!!!!
    Mark Masleh
    E30 M3 / E46 M3 / E83 X3
    here is a pic ot help
    I 'borrowed' a pic from JLee to help illustrate my leak. Note his leak has the photoshopped arrow to it.
    My leak is the round cap with the slot lower middle front of the head. As seen in JLee's pic. Thanks!!!!!!
      Cant remember, but is that the plug for the oil galley? I could be wrong, I think its coolant or oil though.
      Matt
      -Matt
        apparently it's just a threaded plug, probably remove it, clean, and reseal with an appropriate thread sealer
          >>>Cant remember, but is that the plug for the oil galley? I could be wrong, I think its coolant or oil though<<<
          In the photo, the arrow is pointing to the access plate that permits easier service of the intake cam gear. It's just a metal plate with an o-ring and it's retained by those two fasteners. They often leak and a new o-ring and or goop should seal it right up.
          >>>apparently it's just a threaded plug, probably remove it, clean, and reseal with an appropriate thread sealer<<<
          Our heads have two halves. The cam carrier or upper half is the one with the arrow pointing to the access cover on it. The part you showed Mike, is on the actual "head" portion of the assembly. Very few production heads are built this way, part of why they are so pricey to produce.
          Stan
            btw, that's an access hole into the frontside of the timing chain valley area at the front of the head, note there is another smaller threaded plug (Item 2) that fits through it to install on the backside of the valley, probably a coolant galley plug
              Front of S14 engine FYI...
              Stan
                I believe you are confused, please reread the thread
                  exactly, the lower slotted plug
                  This site is amazing, thanks for being such a tremendous resource.
                  So it seems there is confusion as to if this slotted plug is for an oil galley or a coolant galley. Mine has oil seeping from it. Enough that after some heated drives it seeps down the front of the motor and gets everywhere.
                  Next, how do i get that plug out? Is there a special tool? I tried a round piece of steel in my vice grips, that just bent the round steel. Thanks so much gang!
                  Mark M
                    Mark M
                      Re: exactly, the lower slotted plug
                      Mark M
                      There is no galley of any kind behind it -- just open space. Thats the area that the timing chain lives in. I very very seriously doubt that you have a leak there -- much more likely that your leak is below that, at the head/lower timing cover interface, or above it through the distributor housing (rather common leak point -- again, remove and replace the o-ring).
                      Jefrem Iwaniw
                        Re: Re: exactly, the lower slotted plug
                        :cool:
                          Re: Re: Re: exactly, the lower slotted plug
                          :cool:
                          And your point was?
                          Jefrem Iwaniw
                            last time I checked my cap and rotor there was a small bit of oil in there, would a new o-ring in there usually solve that problem?
                            they are not idiots.
                              No -- there's a seal that the rotor base (that piece that has the %@^# allen bolt that always strips holding it in) rotates on. That seal can go bad and allow leaks into the distributor housing. Part # 11 14 1 271 415.
                              HTH!
                              Jefrem Iwaniw
