opinions on a jack?
  • opinions on a jack?
    hey everyone,
    i checked my car (which i bought last month), and it didn't come with a jack so i definitely need to get one. i had 2 questions:
    -where exactly are the jack points on the m3? they seem different on the bottom from my non-m3 e30.
    -what would you recommend for a jack? should i look for an oem bmw jack or should I just buy a 'normal' jack from the auto store? the oem jack will be nice in that it stores away, but i don't put much into the trunk anyways, so space shouldnt be a problem.
    well, lemme know. thanks.
    -Will
    be sure and update your comprehensive auto insurance deductible, life insurance dismemberment policy, and living will prior to buying and using the OE BMW jack
      LOL hahahahahha... thats some good stuff. I wouldnt use the oem jack if I was on the southside with a flat.
      ////Matt
      -Matt
        i took my OE jack out fo the car....i almost ruined my car 3 times using it....that shit is garbage...
        I keep a jack from an nissan maxima in my trunk now...it fits in the stock jack space too....and its much better....just for emergencies.
        I use a realy hydraulic jack when im in my garage.
          Try a Maxima Jack like ADA. There were a few Maximas made and MANY in the junkyard now.
          Hey ADA///M, what year was your Maxima?
          For a shop jack the Aluminium one from Sears works great, I borrowed one from a friend at the track. Nice piece.
            Or you can prove your manhood every track weekend and lug around the steel jack from Sears. Careful, you may well throw out your back trying to get it into the back seat.
              True, but a real man carries a 3 ton trolly jack.....
                Real men don't need jacks
                  i life my car with my teeth!
                  now for on topic, the stock jack is trash, mine almost killed me. i used a nice 3 ton from F&H
                    hahah, you guys are too much.
                    I have a real jack in my garage, but I just needed something for use in case i get a flat on the side of the road or something. I'll go with a non-bmw jack.
                    thanks again
                    As for the jacking points, in the rear, there seems to be a point at the subframe that i can jack up from. what about the front? where should i use the jack? dont wanna break anything or do something stupid....
                      Re: opinions on a jack?
                      Originally posted by marsfire
                      hey everyone,
                      -Will
                      The jacking points are marked with arrows on your side skirts.
                        I am sure someone won't like it, but I jack of the diff case in the rear, and the middle of the front subframe up front. But if you are just doing a corner, see the above post.
                        Will
                          ...I jack of the diff case in the rear...
                          Will
                          couldn't help myself
                          My jack is busted as well, I use the jack from my mom's e46 330 which works fine if used carefully (making sure it's perpendicular to the ground, leaving it in gear, and using the e-brake.)
                          But I do need a jack that I can keep in the car. So what years will work for the Maxima? Any other models? Thanks
                          just found this http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW will it work? (now don't anyone bid this up on me)
                            get an aluminum floor jack to carry with you, and a 3 ton jack for the house.
                              I have a jack from an 90 corrolla and a 98 Maxima both are similar and both work well
