adjusting cam gear
  • adjusting cam gear
    Guys I was wondering with a stock motor, and with 284 - 276 degree cams in it, should I adjust the exhaust cam gear any? Like ive heard retarding the exhaust cam gear 3 degrees, or should I leave everything set at zero.
    Re: adjusting cam gear
    You can do a few different things to move the power band around, but have you measured the valve>piston clearance?
      Good thread on cam timing:
      http://www.s14.net/forums/showthread...&threadid=4308
