Carbon airbox questions
  • Carbon airbox questions
    Can the c/f airbox be used with a non a/n system? For example, I have a piggyback unichip box w/maf conversion. Any problems with that setup?
    it will work. the airbox inlet is ca. 120 mm.
    your MAF diameter should be somewhere around that size too.
      Will there be any benefits using it with this system besides the weight savings? What is the approximate pricing for the carbon box with standard size runners?
      By the way, 120mm seems large. My MAF is only a 3.5inch, I believe.....
      thanks!
      -Alex
