HELP!!!!! Konis and GC camber plates..........
  • HELP!!!!! Konis and GC camber plates..........
    Is there a special Koni adapter for the camber plate bearing, or do I just remove the bilstien plate and have the Koni right on the plate?
    Need help asap car is ready to go together........
    and what about the GC rsm's? Do I just drill out the bushing to fit the koni's larger diameter?
      I would call them. I am pretty sure that there is a different plate for bilsteins. konis, and ground controls advance design shocks. they simply change the lowest plate that sandwiches the needle bearing.
        Up front there is a bushing with two ODs that is used with the camber plates. Out back GC sells a RSM with the proper 12 mm diameter. Or some RSMs can be modified to suit.
        Stan
          Those fuckers, they suck. First they say everything is in stock when I placed my order and it will ship the next day, two weeks later it ships. The guy asked me what I have now and even sayed thank god for telling him I had bilsteins so he could send me the correct koni gland nuts for the strut tubes. This blows.
            Two weeks? I'm over two months and counting for "everything" in stock for my e28. They definitely suck.
