Trunk toolkit
  • Trunk toolkit
    Hi,
    my trunk toolkit is pretty empty. I want to fill the box with all the original tools. Does someone have a picture of a (full) toolkit?
    With a picture I can see wich tools I need.
    This might help? - Click on the correct graphic and see what you want, i
    http://rust.mine.nu/bmw/partgrp.do?m...00&hg=71&fg=05
    Phil
    E30 M3 - The Original Inspiration
      Which car can I find in a junk yard that had this large tool kit shown on the link given by Nostrils?
        IIRC, this was available as an option, but not taken up by many. I think the 7 series and the 5 series have these large tool boxes and I am sure that other 3 series model could have this...according to the Online ETK.
        Phil
          OK thanks for the help
            Heres mine . I'm not sure what the empty space is for , I was told it's a spare bulb holder.
              hey, what's that double-bent allen wrench for?
              Just noticed I don't have that one and it's not shown on the ETK link ...
                one function is to....
                manually open/close windows and sunroof if need be
                  NOTE: The missing gap on the left of the picture is NOT for your locking wheel nuts! If I could scan a picture from the BMWCar Club GB magazine, I can show you what can happen!
                  Someone mentioned to me that the space could be for a gearbox and/or differential socket to open the bolt to check the levels of oil? Seems plausable but I have never seen a complete tool kit, mine is as the picture
                  Phil
                    Brian,
                    If you are referring to the space below the 17mm spanner then I believe that is for the locking wheel nut adaptor. I'm not aware of anything fitting in the middle where the retaining strap fits.
                    Kevin
                    Cecotto/Ravaglia Register.
                      Originally posted by Kevin
                      Brian,
                      I have, what I believe to be BMW original locking wheel caps , but you don't need an adaptor for what is fitted . These are just a locking cap that fit over a bolt .
                      I removed the plastic hanging strap from the middle of the tray, to get a better pic . When folded away , this is where it would lay .
                      I can't remember where I read ,that the space below the 17mm spanner was for a spare bulb .
                        I have recently triede very bulb in the compartment. Nothing fits it; brake light, reverse, turn, interior wedge, nor side marker bulbs will fit. I would either leave it empty,or just tape a small sidemarker bulb in there.
                          i've heard it was a socket apadter for diesel motors.???
                          to pull out the glow plugs or injectors.
                            thanks Bruce, I wonder why it's not shown in the ETK?
                            ///MS
                              never mind, the tool is shown in the sunroof section
