rev problem
  • rev problem
    need help!!!! my car will not rev past 5500rpm. car was running fine then after some time with the a/c on it will not rev past 5500rpm. any ideas?
    I have slowly learned that a huge number of problems of this sort stem from the coolant temp sensor. Check the condition of the connections there. I bet that is what it is.
    Just get a small file and scrape the corrosion off the connections, then plug it in again and try it.
    If that doesn't work try a new sensor....fairly cheap part.
      thanks i will try that. you know now that you say that my temp gauge has been jumping a bit. thank again.
