I need more Juice, so I've been researching Alternator options.
I have heard that the Saab 900's & 9000's have the same geometry of our alternators @ 115amps. But, since the S14 is a buzy/peaky little bugger, I am cautious as to using it since it does not use bushings. It is a nice option without the need of a custom bracket.
Stan has suggested that I have the alternator upgraded to a higher amperage output, or maybe using an upgraded /adjustable regulator pumping out around 14.4 volts. I can have the Altr. rewound (stator) to put out anywhere from 130 - 160 amps, as well as increase the volts to 14.4v.
A stock alternator probably puts out anywhere from 35-45amps at idle. But if the stock unit is rewound to 130-160 amps, it will not average down at idle the way a stock unit does. I've been told that at idle a stock Altr. will give you roughly half the amperage amount. But, the rewound unit will give you anywhere from 20-40% of the total peak amps. So a 160amp Altr. might give you 55-60amps at idle (at most).
Someone even suggested using a smaller pulley on the stock Altr. , but I have assured him that my car can hit 1,200 rpms
, so the pulley would just get whittled down to a pencil point.
What do you suggest? I want greater power at idle without totally killing the alternator up top during peak amps.
Forget about why, think about how? :idea:
