Expansion Tank
  • Expansion Tank
    Could anyone tell me which BM's the m3 shares it's coolant expansion tank with? I've snapped the hose attachment part off it so need a replacement. Should i go to the dealer or will there be ones at local scrapyeards?
    Cheers
    A new one cost me 19 from a BMW dealer , so I'd say get a new one unless its an emergency. Plus another used one is only likely to snap in the same place .
      I believe it is standard E30 fare but
      17 11 2 225 543 coolant expansion tank.
      17 11 2 225 399 expansion tank hose.
      17 11 2 227 683 expansion tank cap.
      m.
        It's not shared with any other BMWs.
          Figured someone would say that so i gave the M3 specific parts numbers, to cma.
            yup, its different. be sure to get the correct expansion tank cap too; the dealer almost gave me the normal e30 one.
            btw, even it doenst seem like you need a new expansion tank cap, doesn't hurt to change it since these things can leak.
              Yeah, just buy a new one. The're not expensive.
                Thank you! dealer it is then...
