I would like to know what is the size of the big opening at the box (where the flexible reinforced hose connects). Is it 5 inches, 6 inches. Reason why I ask is that I am making a similar one for my 2002 racecar which BTW also has the S14 7inch aluminum velocity stacks.
For those who have a CF airbox: 5" or 6"?
Tags: None
Re: For those who have a CF airbox: 5" or 6"?
Originally posted by mfanatics
Yes its 4 1/2". I measured it the other day out of curiousity.
calvin
I could be wrong but isn't the modern induction system have variable geometry?
I thought the larger the intake opening the more you will loose low-end torque but better for the high-end? Porsche GT3 and M3 CSL have smaller intake opening in lower RPM's. The smaller diameter would speed up the flow rate. However, when the intake is applied along with the mapping system (such as the Alpha-N) the aforementioned concept might not be the case.
If any of you can tell me if I am right or wrong I would appreciate.
Mark
Mark
It's a metric size.
I have looked high and low for that correct sized intake tubing here in the US to no avail.
My hose guy (who handles all kinds of ducting too) said its a metric sized ducting.
I tried to clamp the 5" down to it and it sucked.
4" no way.
So I am still using the old original piece I got from Markus ages ago.
If anyone locates some metric hose let me know, I'm in for some.
Cheers
jimmy p.jimmy p.
Even though the copy CF airboxes on the market are of very good quality, it doesn't mean that the DTM machines were using ones with the same specs. I kinda remember airboxes that were way bigger than those copies and had a bigger opening. Let's remember that the more air available immediately, the better the breathing. Which is why a bigger airbox is better. I would not be surprised if bigger airboxes had 5 inch openings or bigger. Just a thought.
The speed of flow at available pressure differential
XXXXXX
XXXXXX
The only pressure differential created in the intake side of a normally aspirated engine is by the movement of the pistons [creation of negative pressure]. There will be no flow without the pressure differential. Agree so far?
Imagine the intake plenum as a control volume area (at constant pressure) and the input and output have to sum up to zero. The amount of torque generated is roughly proportional to the amount of air going through the cylinder head.
Let say, your motor is running at constant 4000 rpm, so you’re consuming a constant volume of air. How can you speed up the flow? The only way I can think of is by lowering the cross sectional area, sort of like putting a nozzle in your garden hose.
So, my “guess” is if you slow the air flow down by opening the plenum, you will loose torque at the low rpm. What I recall is that there were so many versions of Gr. A intake plenums and if what you are saying is true, we would have seen much larger plenums.
And then again, I could be wrong.
if more is better might as well get longer intake runners and throw some fileters on them and make a hood scoupe righ too it. problem with using something that gives you as much air as a dtm box you need a built engine to make it work right
Shes sold now :(
