Repairable ?
  • Repairable ?
    I took my non-cat ' big ' header of the car at the weekend due to a crack on the down pipes which was blowing, and also because of what I thought was a problem with one of the gaskets. This is actually what I found .
    Welding around the outside of the flange looks to be a problem due to the proximity of the mounting holes . Any thoughts ?
    Thats broken
      thats had it get a new one
        What the pic doesn't show to well , is that the pipe sits inside the flange and matches up perfect . Stick the flange on , and you can't even see the crack , which is why I was thinking welding the outside may save what is a desireable part .
        I've already fitted a ' new ' header thanks to Markus , along with a Miltek stainless system .
          a good welder could tig that nicely and it will be all better
          Shes sold now :(
            i dont see why it couldnt be fixed...like voodoo said...it just takes skill and some money...anythign is possible.
              They'd just have to be sure to get the flange on the same plane as the other flanges so it isn't put under tension when installed.
                Brian,
                I can weld it. When do you need it done? I can give you a cat-header if you are desperate to get the car back on the road.
                  Brian,
                  Shouldn't be any problem welding it. I suggest you bolt it up to either another header or a spare head so it doesn't wark when you weld just one of the four pipes.
                  Steve
                  Scottish Cecotto
                    Originally posted by UweM3
                    Brian,
                    Thanks Uwe . I'll speak to you about this and the Eisenmann ,hopefully at the meet in Sussex . Markus got me a new header already , so the car is back on the road . Cheers Markus !
                      Brian,
                      That`s now totally scrap,you better chuck it(just make sure it`s in my direction)
                        bah, easily fixed.
                        weld it on the inside as original, then on the outside lay welds in the areas that won't interfere with the fasteners (that is how it should have been done from the beginning)
                          If you start welding it, take care that all carbon deposit (fom the exhaust gas) is removed around the weld.
                          Otherwise it gets britle cose during welding the metal mixes up with the carbon.
