What ar ethe torque specs on the lower oil pan bolts?
  • What ar ethe torque specs on the lower oil pan bolts?
    Time to stop the little piss dribblettes. :rolleyes:
    >>>Time to stop the little piss dribblettes.<<<
    "Depends" Adult Diapers, and/or no six packs before bed time?
    Or for the S14..I think that the oil pan uses 6 mm fasteners. If they are 8.8 grade (see head) then tighten to 10 Nm / 7 ft-lb. If 10.9 use 12 Nm / 9 ft-lb, according to the charts. Don't overtighten or you'll create a leak. Tighten things down gradually and evenly in a pattern. Not all on one side first for example.
    Stan
      Cheers & thanks!
