e36 or e46 brakes ?.
  • e36 or e46 brakes ?.
    who has done the sway to e36 or e46 brakes and is there a write up or posting of the information?
    I know someone who has the E36 M3 brake conversion. All you need is a hub adapter/spacer to shim the rotor out so that it's inline with the caliper. Bam, you have yourself a "factory" big brake kit with a 315x28mm rotor that are cheap and available everywhere. Same with the pads. The E46 M3 front rotors are about 10mm larger diameter but I don't know of anyone who has done this conversion.
