Leaking coolant from frame rail???
  • Leaking coolant from frame rail???
    I just got done changing the oil and doing the S52 tensioner and now I see coolant on my jack stand?!?!?!?!?!!?!? It appears to be coming out of the frame rail!!!!!! JESUS!!!!!! there is a line that comes out of the front of the tank that looks cracked at the top?...this same line appears to go into the shock tower frame rail....can anybody tell me what the problem may be?
    Sounds like your expansion tank cap is not letting off pressure. The tube is just an overflow tube that goes into the frame rail and out.
    Charley Terhune
    89 Zinno M3- stock 90k miles
    89 Zinno M3- 2.5 etc. etc.
      interesting. Would you recommend that I get a new cap for the expansion tank?
        Yea. They are cheap and go out fairly often.
