How can I cure my rear camber dilema? Is there a solution I can purchase? If so where do I get it from? Do they make adjustable rear camber shit?
Rear camber adjustment
Simply put, the best that ever lived.
"I don't know driving in another way which isn't risky. Each one has to improve himself. Each driver has its limit. My limit is a little bit further than other's." Ayrton Senna, January, 1989.Tags: None
Depending on how far you want to take it there are a few options. There are factory eccentric bushings you could put in, there are also the KMacs but these have been argued to come out of adjustment. There is a Bimmerworld kit similar to the KMacs that is said to hold its adjustment. There are also weld on kits available, but this requires taking off the subframe and welding, these are available from Ireland Engineering or Schatz & Krum. HTHCharley Terhune
89 Zinno M3- stock 90k miles
89 Zinno M3- 2.5 etc. etc.
