I am currently checking the specs on my 2.5L project.
My main bearing oil clearances measured out at .0027", .0032", .0031", .0029", and .0029".
For those of you who have built S-14s, isn't this a bit loose? From what I have been able to uncover, .0027" is supposed to be max.
It leaves an interesting quandary. The way BMW sizes their bearings, you get a red dot crank and red dot bearings, and they are supposed to go together. As far as I know, no other sizes are available unless you go way oversize and have the crank ground. Since my crank, bearings, and block are all brand new, that seems like a ridiculous route to take.
I was curious if there is some variation among "red dot" bearing shells, and if another set might spec out slightly different.
I would greatly appreciate any input or suggestions, thanks.
