car turn off on left turn
  • car turn off on left turn
    Hi guys today I was driving my car when I made a sharp rigth turn and the car turn off I waited for about 1min and car started rigth up has anyone ever had this problem I thought it could be the prime fuel pump but whould like more advice thanks
    I would check your connections where the MAF is as well. Good luck!
      If it only does it on right hand turns it's probably the secondary pump. How much gas is in the tank? If it's less than a half I'd look at that pump.
        Yes it was a little lest than half but I took the car out again and had lest than half tank and nothing happen
        drove it for about 1.5 hr and nothing I'm very concern need help
          I had this happen once when I was low on fuel, it just cut out while I was hard on the gas in a turn. It cleared up and didn't die though as I left it in gear, it hasn't happened since then (which was around 2 years ago).
          Ryan G. MotorWorks
          http://www.ryangmw.com
            I had this happen on a RX7TT, had a bare spot in the fuel pump relay wiring that would only touch bare metal when cornering in one direction, drove me nuts for months before I finally lucked into figuring it out
            you just never know, best wishes for a speedy fix
              happened to me too after a hard left turn - the metal elbow near the front of the intake plenum was loose and lateral G's pulled it right out for me.
              I popped it back in, started back up and went to go buy some silicone sealant... Good luck =)
              -E
              '88 M3 200K+ miles and counting
                Check for a frayed fuel pump ground wire too under the rear seat
