Hello everybody.
I parted out a 1999 BMW M3 coupe 5 speed transmission with 87k miles. I know this is a E30 M3 board but I am assuming some of you guys have other M3s or could use parts from E36 M3 in your E30 cars.
I was going to install the engine an dtranny in my E30 M3 convertible project car but I am postponing the install to a later time so I am selling everything now.
Parts are located in Concord, CA.
All prices are best offer. I will give more discount if you purchase multiple parts.
Please note, all these items has been installed in a working and driving M3 with 87k miles only. The car was vandalized only.
1- E36 M3 complete front suspension, including the strut housing, control arms springs, struts and brake calipers Asking $600 (This is good for e30 318 and 325 cars who want to go 5 lug conversion and have the bigger M3 brake system.
2- Complete rear suspension including the trailing arms, brake calipers, rotors and the drive shafts axles in good shape
Asking $300
3- The rear sub frame ( differential subframe housing) asking $99
4- S52 6 cyl engine, 87k miles. Complete with AC pump, alternator, wiring harness, ECU and everything else. It was running perfect before I took it out of the car. Asking $3600
5- 5 speed manual transmission, again, 87k miles, was shifting smooth before taken out of the car. asking $1250
6- E36 M3 two piece drive shaft $125
7- E36 M3 steering rack $200
8- brake booster with master cylinder $50
9- ABS pump $70
10- radiator $100
11- emission air pump (SECONDARY PUMP) $100
13- OEM oxygen sensors X2 $25 each
14- Front sway bar $70
15- Rear sway bar $70
16- rear springs $70
17- Fronts headlights (left and right) $100
18- Rear working shocks (no leaks) $40
Asking $300
9- ABS pump $70
10- radiator $100
