Alpha-N in 2020 - some questions for a newcomer
    Originally posted by Reelizmpro View Post
    If you are asking for opinions, I would say not to do it. That ship has sailed many moons ago. The point is to maximize engine potential, particularly, those that are heavily modified. I don't say this to trash the method or any particular system. Each option above has it's pros and cons. It's just that I don't think you want to open this can of worms for just induction sound. There's more to it than bolting on a box and switching computers. You will have to learn how to diagnose, tune and keep it in tune, get a wideband, wire in a true TP Sensor, fabricate an air filter, rotate the dipstick, remote locate the brake fluid reservior with 2002 res, move the power steering reservior and finally deal with smog. Alpha N without closed loop means you are flying blind and can damage your engine. Even with closed loop, I've had Bosch wideband sensors fail and had to limp home. I now keep an extra sensor and socket in the car. The risk is high, cost is high and the gains will be minimal on your stock engine which is getting more expensive to replace by the day. There are many good things about it like many have touched on but I feel compelled to discuss the downsides.
    Frankly, I couldn't disagree more. Once it was setup on my car (by me) I literally didn't touch it for 10 years. MAXX was trouble free and user friendly and never skipped a beat. I calibrated the wideband O2 sensor annually and changed it twice while it was on my street car. I then moved MAXX to my track car and reverted the street car to a stock AFM system and have had no troubles yet again. Problem free and easy to maintain. It takes more time to learn the system up front but once you have it set up and the closed loop system dialed in, the whole system works very well
      I don't disagree with Reelizmpro in that the install isn't exactly straightforward. But I do agree that once it's set up there's little to do to maintain it. I've had it in my track car for 15 years and in that time the only thing I've had to do is re-tune it after I upgraded the unit for closed loop.
        I've had Maxx since the first group buy and upgraded to WB closed loop later on. Other than the sensor failing on me, it's been solid, that's why Maxx AN has been the go to system for many of us over the years. I'm not arguing that it isn't reliable, just that one should know what they are getting into having zero experience.
          I am surprised to receive so many responses discouraging me from going down this route. This thread is my attempt to build my knowledge and understanding of the system, even the expert at something was once a novice... I will have it installed and set up by someone I trust. I am an engineer by trade, sadly not in a relevant space, but I'd like to know what's being installed, how it works, and then if there is a need I can dabble myself.
          I'm still trying to sort out answers from my first post:
          • How does the A-N piggyback interact with ECU chips? I have an iigomotiv 91 octane for a stock 2.3L. With A-N feeding the ECU information but all else the same, does this chip work as-is or is a change required?
          • Markus offers a "plug and play wideband setup" for the Maxx A-N, link here, I'm not sure I understand it. Are all of these pieces (and $500) required to use a wide-band sensor, or is it just offering some convenience or something?
          • It seems like a skilled operator can map Alpha-N to be reliable, but I'm still a bit confused about how the motor "understands" load differences, whether it's under full throttle going uphill in high gear versus going full throttle on a flat road in second gear. I believe the intake air temperatures sensor and baro sensor feed into the ECU and can help with changing weather conditions, but I do not understand the "load understanding" story.
          This one, I assume the fact that no one has done it yet is an answer in itself, but I think it is interesting for the sake of discussion:
          • Has anyone made a MAF work with a carbon box, perhaps further 'upstream' in the intake where resonances and plenum bounce-back do not impact it?
          1989 Lachs
          1988 Lachs - sold
          1988 DS - sold
          Car blog
          Bay Area M3 FB group
              • the only thing the 'A-N' does is take the 0-5v AFM signal and replace it with the 0-5v TPS signal. They mapped the AFM signal at all loads and RPM's to create the 'look up map' that corresponds with TPS/RPM at these loads. If you put it on a dyne or use the 'hold the brake for steady state RPM' on the road you can map the TPS corrections pretty damn good, just do a little at a time and let the brakes cool. turn on closed loop WBO2 after doing that and rock on.
              • its not that hard to wire in the signal from a WBO2 controller, the problem is getting the ground reference the same so that the MAXX sees the same as the WBO2 controller. this seems to have been most of the complaints of the integration of the two
              • see answer above
              Both AlphaN and speed density systems are "predictive" load sensing. Based on certain parameters, the map predicts the fuel needed with trimming by the O2 feedback loop. AlphaN uses engine rpm and throttle position. Speed Density uses manifold pressure and engine rpm. The tunner fiddles with the fuel map until the trimming is very small. If the air/exhaust gas path so the air flow changes or gas scavenging changes from when those load methods were tune, both need re-tuning.
              Whereas a MAF load system uses actual measured air mas flow and rpm. If the air/exhaust gas path changes so that air flow changes at any rpm, the system does not need to be re-tuned.
              Additionally there is much less setup on MAF load sensed system. The startup and warmup settings are about the only ones needed. Where the characteristic curve is correct for the MAF the fuel map is all 1.000.
              The MAF is the only one that I have traveled from near sea level to over 11000 ft elev and not have fueling issues.
                Konig - you might want to PM 4DAFUN (Eric Adams) and talk to him about his setup. I don't know him personally, but have met him at several C&C events (nice guy!). He has a 2.5L S14 with a carbon airbox and (I believe) Miller's AN setup. In conversations with him he indicated his system is very strong and reliable. Eric is located in Portland, OR.
                1990 M3
                • #23
                  The Miller War chip has a rough reputation for being a cumbersome and difficult to use setup since you can't make adjustments on the fly. You have to data log, update map, upload new map, shut off car and restart, etc. MAXX you can make changes on the fly and the effect is immediate. I have never used Miller but I've read a lot about it.
                  Konig -- there is only one way to go with this as far as I can say. Reelizmpro said the same thing, it's been the go to system for nearly 15 years for a reason, it's easy and functional and frankly, it just works.
                  • #24
                    Thanks everyone, really great discussion here. I appreciate all of the input.
                    1989 Lachs
                    1988 Lachs - sold
                    1988 DS - sold
                    Car blog
                    • #25
                      Interesting thread and very informative as I'm a newcomer going down the 2.5 rebuild route, looking for tuning options. These all seem archaic for being 2020 and no PnP harnesses for a standalone unless you buy VAC's milspec monster.
                      in my research I've found SSSQuid? I've not seen much mentioned in here but what about just running a simple chip reflash instead of going MAF, etc? https://sssquid.com/v3/
                      no affiliation whatsoever but I was originally going to run the Miller or Maxx setup with the 2.5 but after hearing the tuning stories, difficulty and just not really running right. I'm thinking a simple chip burned for the mods, keeps the AFM and you have stock like drivability and all OEM components.
                      Am I missing something?
                      Chris
                      • #26
                        Well... after reading all these posts, I feel compelled to offer my own experience, however minimal value some people may assign it. Back in 2011, I had my S14 rebuilt into a 2.5L by Metric Mechanic, who at the time fitted 12.5:1 pistons in their “Rally” engine. (Today it’s down to 11:1) Anyway, my TB’s were ported out and port-matched to the head by MM, along with the manifold block gaskets, which today are, damn it, NLA! Anyway, I then got a CF airbox /Alpha AN setup from Markus in Germany. I had all the required relocation of brake reservoir, power steering, dipstick, hoses, etc., done that was necessary for a CF airbox. However, the MAXX AN unit stayed in it’s box, and remains there today on a shelf in my garage, never used and never installed to this day.
                        Enter from stage Left... Dan Miller at the 2012 E30 Picnic, who put a bug in my ear to instead use his MAF and WAR chip at the time instead of the MAAX AN. So I did... after some serious head scratching to modify his MAF to mate with a CF airbox and actually work, even finding the right air filter for it. In the end, it’s a rather simple modification to the MAF... by cutting off it’s 4-bolt flange, and sourcing a couple of silicon reducers from 4.5” to 4” and a couple of band clamps, and a K&N cone filter whose wide mouth sits in the snorkel t the lower band clamp and extends down past the oil cooler. I was lucky in that Dan Miller himself came down to Portlan from BC and Seattle, just to tune my car and the WAR chip, twice, using a Mustang dyno. Once dialed in... it ran flawlessly for 5 years, passing DEQ smog every time. Until... the 2016 E30 Picnic in Tacoma, WA. Enter stage Left... Dan Miller, “Hey, Eric, nice to see you again! You know, you should really upgrade your MAF to my new Miller version of Alpha-N!” Me... “Oh, really? Your MAF is still working great!” (I’m thinking don’t fix what ain’t broken) Anyway... he proceeded with the sales pitch and of course I fell for it. $700 later, and a whopping 10 minute install by Dan Miller himself in his Seattle shop, and him actually tuning it himself, I now have been running his version of Alpha-N since 2016. It sails through Oregon DEQ smog testing, yet now i will have to pony up for a new CAT, as mine has now decintegrated after 15 years, most likely from scraping on speed bumps. I’m looking at the VSR1 version now, and maybe an Eisenmann Race muffler, but that has nothing to do with the CF airbox question. I’m not knowledgeable enough in either the MAAX AN or the Miller MAF+ WAR chip / Miller AN + WAR chip options to explain how and why they work, or the pros and cons of one over the other. All I can offer is my experience of modifying a MAF to fit and work very well with a CF airbox, along with the later Miller AN. Both work well.., both were tuned by Dan Miller himself. Perhaps that alone is my unfair advantage with the Miller setups. Living in the Pacific Northwest has its own advantages I guess. If however, anyone wants pics of how to modify a MAF to fit a CF airbox... send me a PM. I would post them here, but am not sure just how to from my iPhone photo library.
                        Just my 2-cents worth of food for thought...
                        Eric Adams a.k.a. as “4DAFUN”
                        Gladstone, Oregon
                        Owner of my Zinno ‘89 E30 M3 for 24 years.
                        4DAFUN
                        Eric Adams
                        Portland, Oregon
                        • #27
                          Chris
                          No argument from me, a nice chip will perk the motor up nicely and minimal headaches. The only thing you'll be missing is the induction sound and slightly improved throttle response. Thanks for sharing the SSSquid deal, I'd not heard of that before. I see some positive reviews on r3vlimited but haven't seen anything for the M3. Here's the relevant direct link for the S14:
                          https://sssquid.com/v3/ssshop/s14b23-chip/
                          A friend of mine who's been in the game for longer than I have brought up this product as well:
                          http://rongineer.com/airbox.html
                          It seems to be an OE-style airbox to be run in conjunction with A-N. I feel I'd just run a carbon box because the hard work is all in the A-N system... indeed its main purpose for me is to enable the carbon box.
                          1989 Lachs
                          1988 Lachs - sold
                          1988 DS - sold
                          Car blog
                          • #28
                            https://www.r3vlimited.com/board/for...lphan-n-for-m3
                            Dropping this link in here as good reading, I'm not sure how I didn't see it before.
                            1989 Lachs
                            1988 Lachs - sold
                            1988 DS - sold
                            Car blog
                            • #29
                              Gladstone, Oregon
                              Absolutely an unfair advantage but what if something goes out of whack and Dan or Brody stop answering calls for help? For the last 5 years or so people have been complaining about the lack of support on R3v. Martin and John are no longer active but Maxx has been running 15 years now and is straightforward with plenty of support if you need it from members here.
                              https://www.r3vlimited.com/board/for...er-performance
                              Konig...here's a better thread discussing differences between Miller and Maxx AN.
                              https://www.r3vlimited.com/board/for...alpha-n-system
                              sidenote: BattleM3 who was the guinea pig for Miller AN had the system removed and went back to stock.
                              • #30
                                Continuing to share my thoughts / check my understanding, this time with respect to wiring modifications for installation. Referencing the Maxx installation document here.
                                Section 2: TPS, the connectors need to be pinned in a different way. In section 2.2.2 Maxx offers a crossover adapter, so that can be plug-and-play.
                                Section 3: air temp sensor, adapter is included.
                                Section 4 and 7.1.1: modifications at OE Motronic harness.
                                Pins 2 and 3 are pulled out of the OE connector and hang free. Two new inputs from the A-N unit take their place in the OE connector. The remaining pins, except for 7, are crimped into the connectors together with new inputs from the A-N unit and then go back into the OE connector. The original Pin 7, which is the AFM signal input, is connected to the POT-G wire from the A-N unit. A new input from the A-N unit takes the place of the original Pin 7 in the OE connector.
                                From this, I gather that if I install a complementary fitting on the POT-G wire from the A-N unit, I can leave the original Pin 7 wiring untouched and have a plug connection instead of tying them together with a solder or more permanent joint.
                                When the time comes to disconnect A-N and the airbox, I do the following:
                                1. Reinstall stock airbox hardware
                                2. Remove the Maxx crossover adapter on the TPS and plug the original harness back in.
                                3. Remove the Maxx air temp adapter and plug the original harness back in.
                                4. At the Motronic connector, push pins 2, 3, and 7 back out. Re-fit originals pins 2 and 3. Pull apart my plugged connection on Pin 7 and re-fit the original pin 7.
                                In theory, at this point the car has all of its original hardware fitted and is back "as stock." Is my understanding correct? Will the ECU be upset that I have 6 instances of doubled-up wires that are still connecting the A-N unit to the ECU? Some of them look like power/ground to supply the A-N unit but I'm not sure about Pin 8 (PPU [?]), 24 (Lambda), and 33 (idle valve position). In theory the A-N unit will still be on board, receiving power, but lacking any input for Alpha and, if it still tries to provide values, its output of a calculated AFM position will not be connected to anything.
                                If this is all true, it's tantalizingly close to plug-and-play...
                                1989 Lachs
                                1988 Lachs - sold
                                1988 DS - sold
                                Car blog
