i am trying to run Maxx AN with closed loop on my newly rebuilt stock S14 with an Innovate LC2 O2 sensor and a stock ICV
I assure you I have spent a lot of time reading Maxx literature and pretty much all of the threads on here regarding AN and double checking the AN wiring integration into the motronic connector/ engine harness
. I can do the basics - go online with the AN module and download maps . I have gotten the thing running with various configurations and various results, none of them very good.
So i am still working really hard to understand some basic wiring and functionality of the AN software and hardware so that I can tune.
Help me first confirm that the lambda control is wired correctly. Based on the two tidbits from the Maxx literature below ( and the Maxx wiring schematic) I have wired the NBsim signal into the black wire on X3-6 that feeds into AN plug at E and jumpered it into the ECU pin 24.
Obviously this wiring provides the NB sim signal To the motronic and the AN and is the signal that the ECU needs to control lambda.
Additionally, the WBlin signal, via X3, is fed to AN F and allows AN to display AFR’s.
Reference From Maxx:
Addendum
If idle valve is not used (some racing setups), wire 33-J can be left open.
If you don’t want to view the signal of the oxygen sensor or no oxygen sensor is in use, the wire 24-E can be left open.
1.1 Narrow-band-signal NBsim
The signal NBsim may be connected to the X3 connector at pin 6 ( AN input E).
The harness connects this signal via the X3 connector to the Alpha N plus and also to the associated mo- tronic side narrowband lambda input.
In this case it is important to remember that the stock narrowband connector on the engine harness (nor- mally connected to your stock lambda sensor) remains disconnected!
In this way, it is possible to retain the stock lambda (0..1V) control without having to use an additional narrowband sensor. If the stock lambda sensor is to be used, then pin 6 of the X3 connector should not be connected.
So far so good, I think, but trying to understand the control functions is where it all goes fuzzy for me (and where the advice in threads seems very inconsistent)
The AN guidance above says the motronic is best left to control lambda, yet the whole idea is that AN provides closed loop feedback. So how does that work?
threads say turn lambda control off (via F10). That allows motronic to solely control lambda, yet AN is generating compensation factors as it Compares read AFR’s to your fuel map for various throttle positions and RPM.
That really confuses me. Is AN actually controlling or just generating compensation factors to guide you on changes to your fuel map? If you are adjusting Fuel delivery via your fuel map, How does that square with what the motronic is trying to do?
Just don’t understand. Can someone help me get it?
Addendum
