Bought a 90 M3 with alpha n box and unknown carbon fiber intake box. The car would run full rich on my AFR gauge on full throttle (10:1AFR or richer). Is this normal?? Idle seems fine, fluctuating between 12-14:1 AFR. Would like to know if theres anything I can do to make them leaner. The car also felt a little slow or flat on full throttle. thanks
alpha n running rich
I don't suppose you know what alpha n u r running? Maxx? Any pics ? Either way, it sounds like u will have to find a tuner.Last edited by Reelizmpro; 02-20-2013, 08:18 PM.
A little off topic, but I've been starting to go through the slow tuning process myself. I'm running Maxx off my WBO2 and the car runs rich too but it's adjusting the fuel map from -6 to sometimes hitting -15. My question is if it's rich across the board is there a easier way to lean out the whole curve or should I just start slowly leaning it out? I feel that if I can adjust the whole curve so its adjusting from 0 to -9 its a better starting point.... Probably a real stupid question.
Thanks,-Darren
