I've been working on this for about 18 months. It's just about finished, just a few more little projects left. Its an 88 (6/87 build) with a 97 S52. The color is called Techno Gray, it's a Saturn (GM) color.
You need to get a heat shield for that cone filter. It will get you a few extra horsepower since you are sucking in hot air from the engine. You can also run the filter to the headlight and get slightly better throttle response.
