E30 m3 s38
  • E30 m3 s38
    Technical information
    Engine BMW M5 3.8 6-cylinder, 24 valve (S38B38)
    Cylinderhead
    Cylinderhead flow / mm / hp
    2 mm 123,5
    3 mm 186,2
    4 mm 251,6
    6 mm 354,7
    8 mm 429,8
    10 mm 481,4
    11 mm 502,3
    12 mm 520,6 (201,8 CFM)
    14 mm 542,1
    15 mm 558,1
    Inlet valve 39,5 mm Schrick (blanco own desing)
    Exhaust valve 32,5 mm orginal
    Massive cylinder head flow works
    Schrick valve spring / titanium retainer and lash cap
    S50B32 Cam follower
    Adjustment camgear
    Camsaft
    Schrick inlet cam
    308 degree / lift 12,2 mm
    Schrick exhaust cam
    296 degree / lift 11,7 mm
    Throttle body BMW M5 3.8 (S38B38) 50 mm
    Injector Bosch 420 cc / 5 bar
    Air filter ITG Megaflow special made
    ECU Haltec E11v2
    Ignition MSD 6 AL / distributor
    Exhaust manifold 6 – 2 – 1 Stainless steel. Secondary pipe (adjustment)
    Thermo coated
    Exhaust pipe Stainless steel plate (made by pipe) 3” and hand made mufflers
    Piston C.P.S Pistoni special, bore 94,6 mm (balanced)
    Connection rod Auto-Verdi, light (balanced, top and end)
    Cranksaft Orginal S38B38; balanced
    Oil system Orginal and bigger oil cooler
    Compression ratio 12:1
    Power 450 hp / 7030 rpm (exhaust manifold restricts max power)
    Torgue 485 Nm / 6100 rpm
    Torgue range 3000 rpm / 355 Nm / 4000-7000 rpm +430 Nm
    Flywheel Steel 4,0 kg
    Clutch Alcon 184 mm twin plate
    Gearbox Sport Getrag 265; factory Group-A race gear ratio and direct gear connection
    Differential 4,27 / 75% limited slip
    Steering 2,3 round to left-right
    Suspension
    Front axle
    BMW E36 up-right
    Öhlins 36HMRCW 2-way coil-over McPhersson strut
    Uniball top mounts including camber and height adjustment
    Anti-roll bar 34 mm steel (BMW M3 DTM) Dolate-Motorsport
    Front whisbone; adjustment / uniball connection
    Rear axle
    Öhlins HMR 350 3-way coil-over shock absorber
    Camber and toe adjustment trailing arms
    Uniball connection
    Brakes
    Front axle
    Alcon CR6380 monobloc
    Disc; 355/32 mm
    Caliper; 6-piston
    Rear axle
    Alcon caliber; 4-piston
    Disc; 330/28 mm
    Wheels
    ATS DTC 9 X 17”
    Body orginal E30 M3
    Carbon parts*
    front hood*
    rear hood*
    bumpers*
    doors*
    DTM front- and rear spoiler*
    lexan/polycarbonat front/rear side windows and rear window
    rollgage(18 mounting points)
    Sparco Corsa seats
    Sabelt safetybelts 6-mounting points
    Weight
    1140 kg whitout driver
    More picture: http://kuvablogi.com/blog/6155/
    very nice car
    if youre interested in participating estonian open track events, i can help you
      Looks like an amazing car. I love the choice of engine.
      Love the 2 wheel action
      Terrance
        Remove
          Originally posted by Camber View Post
          Remove
          huh? Nice car though. Neat and tidy install.
            Admin remove please!
              Please shoot me a PM me with a reason. We generally do not delete threads.
              Jake
                On my computer, his first post is black letters on the black background....Unreadable.
                Anyone else have that problem?
                Maybe he wants it deleted to re-post?
                  yeah....can hardly see any text.
                    Cylinderhead
                    2 mm 123,5
                    3 mm 186,2
                    4 mm 251,6
                    6 mm 354,7
                    8 mm 429,8
                    10 mm 481,4
                    11 mm 502,3
                    14 mm 542,1
                    15 mm 558,1
                    S50B32 Cam follower
                    Adjustment camgear
                    Camsaft
                    Schrick inlet cam
                    Schrick exhaust cam
                    ECU Haltec E11v2
                    Thermo coated
                    Suspension
                    Front axle
                    BMW E36 up-right
                    Rear axle
                    Uniball connection
                    Brakes
                    Front axle
                    Disc; 355/32 mm
                    Caliper; 6-piston
                    Rear axle
                    Disc; 330/28 mm
                    Wheels
                    ATS DTC 9 X 17”
                    Body orginal E30 M3
                    Carbon parts*
                    front hood*
                    rear hood*
                    bumpers*
                    doors*
                    Sparco Corsa seats
                    Weight
                    Reabable now
                      fantastic build! this calls for video..
                        Damn this is gangsta!!!:fire:
                        No Bitchassedness:battle:
                          so sick!!!
                          post more pictures
                          @slowprogress
                            Holy shit! :OMG:
                            You made that power NA!!! :surprised
                            Any vids? That's a low 11 second car right there! That thing must fucking rip!!! :drive:
                            Castro Motorsport
                            12600 Sherman Way, Unit C
                            North Hollywood, CA 91605
                            (818) 765-3606
                            The Purple ///Monster Build:
                              It is very important to me that you post videos of this car. Subscribed.
