This will be probably be similar to Jason's "Rose" as his pics are what we going off in putting in the S54. Was going to push it back further than what Jason did, but it is impossible to go back further than 4.5 inches using the stock dual sump pan unless you go back another 6 at least which presents a whole nother set of issues. Could do a few more inches but this will require a dry a sump. Might do this in a year or 2 but not now. Time crunch to see if I can get this ready for Winterfest.
Now for the pics...
Front end E36 style. Removed the core support. Will modify to allow it to bolt back in place mostly as is. We are working on trying to get the radiator tilted back a bit (actually the bottom of the radiator forward a bit) to help vent all the air that goes thru the radiator out the hood vent. I used to drop the subframe out of the car to get the engine out, this will now make it easier to slide the motor out the front.
2nd pic is the rear parcel shelf removed. Will put a new panel in there that is smaller due to having the fuel cell requires it to be isolated from the passenger compartment.
Now for the pics...
