My Turbo Manifold has arrived
The BMW 2002 Turbo that had basically the same block as the S14 had the KKK turbo fitted on the side of the block, not above it. any reason why fitting the turbo above the head?
http://www.7-forum.com/news/2006/you...p0025853-b.jpg
Originally posted by LeeVuong View PostThe BMW 2002 Turbo that had basically the same block as the S14 had the KKK turbo fitted on the side of the block, not above it. any reason why fitting the turbo above the head?
If you look look at the 2 stickies, Anders and Dave both go via the top. Also many Swedish S14 turbo conversions are on top.
Aldo I did not want an intercooler pipe rounded over the top. All the pipework is underneath and a neater finished in my opionion
Mounting of the oil cooler2 Photos
The latest update. The fuel cell with swirl pot and fuel pumps added. Fuel lines added too.5 Photos
Large Carbon Fiber Splitter from Marcus5 Photos
Fuelling done
Much work has been done, turbo cooling and oil feeds, intercooler pipework, along with oil cooler. Radiator moved over to the opposite side at the front and the air filter is located through the floor panel behind the headlight in front of the air duct to avoid hot air from the engine bay.
polycarbonate windows with heated front screen.
flocked dash with new LCD display and operating buttons with boost and traction dials. Eco and control boxes installed.
The engine has been tested for oil pressure and on turnover peaked at 65psi.
plenty of other smaller parts completed. Pictures in next post
These are probably needed to haul in the 450bhp1 Photo
Fuel Cell set up finished1 Photo
Some interior pictures. The battery and fire extinguisher system. The wiring will be a can bus system with 2 16 channel power boxes. This eliminates the need for relays and fuses. The terminals have led lights that are green when functioning correctly or different colours when not. The dash has been flocked and a 16 button keypad for the pumps, heated screen, starter button, diff cooler etc. On the top of this box extension are 2 dials for the traction and boost. The ABS unit has been removed and the ECU controls the level of traction. The screen surround has been painted back to reduce the glare.4 Photos
