Or...I need a mentor.
Just trying to do some research. Had another S54 fail this past weekend. That's 3 in about 15 months. Thinking about another motor. 2 of the options are turbos. And I know nothing about turbos so SURE why not?
Letting the cat out of bag if I do this...but here goes. The 2 options are an S14 and an M50. I already have the firewall moved back for the S54 so the balance issues are a non-issue. The main rule is they have to have a displacement of no more than 1986cc. The S14 2L is actually 1990 cc...so I'd need to remove 4cc of displacement. I have a lead on an M50B20 which I think has a displacement of 1991cc....so need to remove 5 cc. I can either sleeve to reduce bore or destroke. It appears the S14 needs to be destroked 0.2mm. Either option needs a machine shop that is competent to do the work. It appears that the M50 has a bore that is significantly less than its bigger brothers (80mm vs 84+). My S54 was about 350rwhp. That or a bit more (I have no fears of running 104 all the time as I did it with the S54) would be nice.
Thoughts?
What are the options out there for turbo S14 parts? Like the header in particular.
Thoughts?
