Originally posted by Mr Deagle
View Post
Bry's Megasquirt Install
Bryan K.
Texas A&M Formula SAE
Originally posted by Spulen81 View PostAssuming you are using an S14 engine it doesn't have a 60-2 wheel from the factory. I wish it did.Most of the other 6cylinder and later four cylinders use the 60-2 wheel.
It has two crank sensors. One is a single tooth TDC sensor and the other reads off the 116 tooth flywheel ring gear.
:thank you
Bry, James' post re: Tach output worked for me... the key is to make sure it doesn't ground out... I blew a resistor using a metal screw instead of a nylon one.
http://www.s14.net/forums/showthread.php?t=23302&page=4Last edited by ///schwartzman; 12-14-2007, 08:17 AM.Rich!
I'm not using EDIS, I'm still using the stock coil, so I don't have a PIP signal to work with. Any ideas on how to get a tach with the stock setup?Bryan K.
Originally posted by Mr Deagle View PostI know how it works.
I'm just messing with ya, I love to see people playing with their E30 M3's. I would have originally gone with a commercial unit, but the low cost was so appealingBryan K.
Originally posted by ///schwartzman View PostI'll ask my engineer Fernando tomorrow... why did you stick with the stock unit?Bryan K.
Originally posted by Bryan View PostI originally didn't want to wire in a new ignition system (I wanted to get the car running), and I didn't really like the edis. I eventually want to do a COP setup!
I wanted COP too, but the mods to the valve cover was enough to change my mind... at least for now, but they make the S14 look modern.Last edited by ///schwartzman; 12-16-2007, 06:03 AM.Rich!
more tach circuit possibilities - megasquirt
This relates to the tachometer circuitry that I posted earlier in this thread. I found this info while researching my own megasquirt build. I believe this is the setup that others have used to get a tach singal for their instrument cluster on E30's. I know that it has been used on E34's.
The circuit is built in the proto area and is as follows:
see the link http://forums.bimmerforums.com/forum...ght=megasquirt for the write up on this instl. Warning, there isn't much about the tach circuit instl in the write up. The write up does say to use a 100K pot instead of the 50k called for in the diagram. This agrees with the variable resistor info from my previous tach post.
I was hoping some one could help explain the some circuit wiring to me.
Where should the "12V ignition" come from?
Also, I believe the "to tacho" is what actually supplies the signal to the instrument cluster tachometer. It would actually wire to the DB37 connector (SPR4 for example or IAC1A if a stepper icv is not being used) and then be wired from the connector to the OEM tach.
Finally, I do not understand the "to the selected pin on the pcb." Which pin??? This doesn't make sense to me unless they mean to wire it to a pin on the DB37. I don't expect this is the case because I suspect the "to tacho" is what is wired to the DB37 to supply the tach.
Obviously I'm not sure how this circuit is wired. Can anyone with more megasquirt experience or circuitry/EE experience shed some light on this?
12v ignition comes from any 12v on the pcb after the input filtering circuitry.
To tacho goes to any free pin on the DB37
To selected pin on pcb goes to the 5V signal that goes either (1) to the base of the high current ignition driver (if you're using the stock ign coil) or (2) to the EDIS module.
HTH
jimmyC
'To selected pin on pcb goes to the 5V signal that goes either (1) to the base of the high current ignition driver (if you're using the stock ign coil) or (2) to the EDIS module.'
Actually, if this signal is going directly out to an EDIS module, you'll have to add a 470 or 1K ohm resistor in line with this signal to the transistor
Bryan,
Did you ever get your tach working with your setup? Any more observations on your setup after another 8 months or so? Do you think you made any compromises sticking with the stock distributor setup or are you happy with it?
I'm considering pulling the trigger and doing Megasquirt myself - probably the new 3.57 board.
TIA,
Brendan
Hi Brendan,
To be honest, I haven't messed with the tach at all. With the new firmware updates, I really want to upgrade my MS and at the same time, work on fixing the tach. I also want to play around with launch control functions too!
You should make the plunge for megasquirt. Just make sure you know you will be playing around with the tune for a while. Actually, it kind of makes your whole car a "project" where you are always working on it. I've been having a problem with noise in my TPS signal, so I'm going to try to run a new shielded wire to see if I can fix it.
I am glad that I kept the stock distributor for ease of implementation. It would be fun to have a distributorless setup, but I think the performance increases that it would give me on my setup would be negligible.Bryan K.
My ideal situation involves Sequential and COP, but I think I should start with the stock distributor and learn what I'm doing first with more basic tuning before I throw even more complications into the mix. As for being a project I'm always working on, well, I'm already there anywaysI want to start the engine upgrades at some point, and figure I should get the tuning aspect under control first, and I have a lot of time on my hands now through the fall, so basically Megasquirt makes sense right now...
How much do you know about the 3.57 SMD board vs the 3.0 board? I am not interested in soldering it together myself, and just assumed I'd go with the 3.57, but it is newer with fewer people using it. Any thoughts on that?
