2.5L Rebuild Question
  • 2.5L Rebuild Question
    Whats going on everbody. I have a 1991 M3 and I am going to be doing the 2.5L bottom end upgrade from turner motorsport. I have done the 2.5 on an 89 that I owned a while back so this will not be my first time. I am curretnly in the process of making a parts list and would like everyone to read over it to see if you guys would recommend anything necessary ( yeah we all could use a stage 3 head but i have limited funds)or if I am forgetting many replacement parts.
    TMS 2.5L bottom end kit which includes
    Oem BMW crackshaft w/ bearings
    nut spacer for crank
    2.5L head gasket
    bottom end gasket set
    TMS custom 2.5L chip
    2.5 forged pistons (11.25:1)w/ rings
    rod bolts/head bolts
    Replacement Parts
    Water pump & thermostat
    Oil pump w/ chain
    Timing chain
    Timing chain tensioner E36 w/ spring
    Upper chain guide
    Left chain guide
    Lower tensioner rail
    Upper tensioner rail
    Cap/rotor/wires/plugs
    Oil filter
    Fuel filter
    Valve cover gaskets (all 3 pieces)
    Belts: alternator/PS/AC
    Parts I will inspect to see if they need replacement:
    Intake gaskets
    engine mounts
    trans mounts
    clutch assembly
    seals for transmition
    Please give me so input. I would like to order all my parts and have them ready. I know I will be held up by a few parts here and there but I would like to be as ready as possible. Also if you guys know the cheepest place to order the parts from that would be cool. Let me know. Thanks ahead of time you all.
    Matt
    91 M3
    My baby is always under construction...
    I have that 2.5 kit chip if you want to buy it.Less than Turner if he will exclude it from the kit.
    Exhaust studs & nuts
    Rubber high press fuel line
    Injectors cleaned & flow balanced
    3 oil filters for break in period
    Case of 10W40 oil for break in period
    Coolant hose set?
    Valve shim kit for adjustments
    Buy the Motorsport valve springs and install them while the head is off. If you ever upgrade, or sell the car, you or someone else is set for an easier cam upgrade!
    HTh Eric
      Re: 2.5L Rebuild Question
      ENGRISH????
      You have to watch out for the bad CRACKshaft dealers...they may give you some bad shit....
      Im sorry i had to do it.... :evil:
      Anyway your list looks OK...the standard things....definitely get new exhaust studs/bolts....id replace the hoses(taylor autosport silicone hoses )
      Just purchase the timing chain kit...you'll save some money instead of purchasing each piece seperately...same goes with a head gasket kit(although you are getting the head gasket in the 2.5L kit)...
      Maybe replace/resurface/lighten the flywheel? New clutch?
        How much would you sell your kit for. I can get the TMS kit for $1,700. Let me know.
          How do you get the TMS kit for $1700?
          Tony
            Lets not forget the lower and UPPER oil pan gaskett ! Maybe a few bolts for it too...
              i wouldnt just jump into the turner kit. it may be complete, but you should shop around. there are better prices out there
                I offered you the CHIP for that kit which is designed to be used w/ a 2.5 bottom and all 2.3 stock induction.
                I do not have the whole kit for sale
                Eric :p
                  I was going to purchase the kit from a guy that bought it from TMS and back out of doing the kit. I have not talked to him in a few days so I dont know if the $1,700.00 deal is still on. The last time I did the 2.5L I had a friend buy all the individual pieces from various places with his dealers licence so he got the whole kit fairly cheep. The only bad thing is that it took 2 months to get all the parts. Who else sells the complete 2.5L kit and does it come with a 2.5L chip. I plan to have the car custom tuned in the future but I would like to have the car run close to what it should with the bottom end upgrade. Also, I am thinking of upgrading the valve springs and do cams. What is your imput on cams. I was think of doing schrick's. I want the car to be drivable on the street but would like some top end power. What schrick cams should I do and what prices have you seen them go for. Thanks
                    How much costs the 2.5l crankshaft in USA.?........
                    part number 11211316978
                    Markus
                      Re: How much costs the 2.5l crankshaft in USA.?........
                      Markus
                      600 bucks and an 80 dollar core charge. Barry knows the exact price
                        I have all these parts for less than anywhere on the net
                        2.5 evo3 BMW crackshaft w/ bearings
                        nut and spacer for crank=$550
                        2.5L head gasket set=$250
                        bottom end gasket set=$35
                        TMS custom 2.5L chip=$150
                        E30 M3 Evolution Front Brake Rotors=$150
                        TMS/Wiseco 11.25:1 piston set for use with the Evo3 2.5 liter crank and 2.3 connectig rods. The pistons are 95mm bore with rings, wrist pins and clips=$600
                        Schrick 284/276 cams=$899
                        Prices do not include shipping
                          Thoes prices sound very good. I am assuming all parts are new, am I correct? Please give me your number so I can contact you. I will purchase the parts from you. Thanks
                            One more thing....I was told I needed motorsport valve springs, adjustable cam gears and evo injectors with the schrick cams. Are you able to supply these parts and if not where is the best place to get them. Thanks again.
                              All parts are brand new,check your pm for my number.
                              I am getting some cf airboxes built for real cheap,not no $1000+ dollars for a lighter box with no performance gains.Same specs as stock but cooler and lighter for about $500 or less.Basically,I do not need to make money of selling car parts.I have my jay o bee for that.
