Cheers Jake. It's all your fault [peace]
The full results...
Piston A
3.66
3.66
3.56
Average 3.63
Piston B
3.46
3.56
3.46
Average 3.49
Piston C
3.36
3.46
3.46
Average 3.43
Piston D
3.96
3.86
4.06
Average 3.96
With a bit of juggling of the smallest pistons to the largest chambers, I get the following combination...
Chamber 1 - Piston C Compression 11.91:1
Chamber 2 - Piston D Compression 11.885:1
Chamber 3 - Piston A Compression 11.93:1
Chamber 4 - Piston B Compression 11.935:1
This gives a spread of 0.05:1.
Because I have 0.25mm of the dome left on each piston I can loose a little material to try to equalise. But, this nay effect the balance of the pistons, so I can only take material off the heavy pistons. I will look in to it and post back.
Just to put in to perspective 0.05:1 difference in compression is 0.27cc or about 0.1g of aluminium.
Steve
The full results...
Piston A
3.66
3.66
3.56
Average 3.63
Piston B
3.46
3.56
3.46
Average 3.49
Piston C
3.36
3.46
3.46
Average 3.43
Piston D
3.96
3.86
4.06
Average 3.96
Steve
