235/40's on 17X8 et40?
  • 235/40's on 17X8 et40?
    I would like to put on a set of 235/40 Toyo R1R's. I know these are an inch larger than the stock diameter, but wondered if I would have any issues with them rubbing?
    1991 BMW M3 Alpinweiss
    1993 Mazda Rx7 R1 20b Black
    1990 Corvette ZR1
    1987 Ferrari Testarossa
    2007 Maserati QuattroporteAccount
    Some have had issues with that size rubbing up front. You should not have an issue with the rear in that size at all (99.9% sure that you'll be good with the rear). The ideal size is 245/35/17 which is also a size that is uniquely offered by the R1R range. I have the 245/35/17 on all four corners with a front 8 inch /rear 8.5 inch wide staggered setup.
    If looks could kill...
    ///freshM3 piff :rastajake:
      Damn. That's helpful. Thanks, much. I'm on it.
      1990 Corvette ZR1
