Kosei K1 17x8.5 ET40
  • Kosei K1 17x8.5 ET40
    Is anyone running this wheel? If so, are you also running a spacer? If yes, what size spacer? 20mm? I am looking for some 17 inch track wheels and Tirerack has these. I checked with Bimmerowrld and the APEX ARC 8 wheels are not in stock. Thanks.
    -Sean
    I'm running them with a 15-16mm spacer. A 20mm spacer would work as well.
      Thanks, appreciate it. I assume that you are generally happy with them?
        I am, They're super light. One thing I should mention is my car isn't super low. I do have coil overs but my strut housing aren't shortened. I'm running 245/40's Nankang Ar-1's without rubbing.
          Great, thanks. Do you know if they are hub centric for our cars or do you need to run a ring?
            e36 Kosei's have the same hub bore as e30 M3's. So get which ever MM spacer you decide and make sure it's e30/e36 hub bore diameter. No need to get a hub centric ring if your running a spacer.
            • Sean
              Sean commented
              Editing a comment
              Thanks very much!
            Koseis great track wheel. Have had many sets with no issues.
            Apex out of stock everywhere in 17in e30m3 size. According to apex, no plans to make them again in near future.
            I got the last set of 17in team dynamics wheels in e30m3 size from Bimmerworld last week. None of those are going to be in stock again either.
            75 M2
            88 M3
            • Sean
              Sean commented
              Editing a comment
              Thanks very much!
            Thanks very much. -Sean
              I have a set of Apex wheels I would sell. E30 M3 fitment. Not sure they would clear the BBK without a spacer thou. I'm thinking, Apex E36 fitment would be ideal for you. 17 x 8.5" with 20et spacer is VERY AGGRESSIVE. You might be better off with 17 x 8" or even 17 x 7.5" front and 17 x 8.5" rear with square tire setup.
              E30M3 is a Legend
              • Sean
                Sean commented
                Editing a comment
                Thanks very much!
              bmwdayz - I am curious how you are running a 8.5" wide wheel in ET40 with a spacer and not get any interference with the lower spring perch or the spring. A 15mm spacer nets you ET25 and a 16mm spacer nets you ET24. I don't see how either would work even with coil overs. Especially if you are running a 245 tire. 8" wide wheels usually need a minimum of ET22.
              Pictures might help me.
              I am looking at the same Kosei wheel (17x8.5 ET40) from Tire Rack and don't want to order something that doesn't fit.
              Thanks.
              1990 M3
                Thanks.
                I'm running GC Coil Overs without shortened Strut housings. I can snap a few pictures of my setup tomorrow for you to see.
                  If you could I would really appreciate it.
                  Thanks!
                  1990 M3
