Massive 332mm BBK w. Superlite calipers and 16" wheels
  • Massive 332mm BBK w. Superlite calipers and 16" wheels
    Anyone been able to pull it off? It will probably reuire very low offset wheels.
    Am I nuts or has no one even tried this?
    James
    James
    Hi James.
    Unless you run BBS Motorsport 3-piece wheels with flat barrels (rims need to be disassembled to remove the tires), I am afraid it will be a no fit. The overal diameter, including the calipers is 14-3/8". And then the calipers might need to be quite far from the spokes (thick spacers) to clear the round portion where the spokes meet the barrel.
    The Rally kit with 11.75" x 1.25" discs will clear 16" wheels though.
    Here's a 16" x 8.5" et 25 Hartge wheel with 13mm spacers to clear the caliper.
      Thanks Lee!
