245/35/17 tires on 17x8.5 wheels
  • 245/35/17 tires on 17x8.5 wheels
    I tried doing some searching with no luck. Anyone running 245/35/17 tires on the front of their M3 with a 17x8.5 wheel? I'm contemplating some Toyo R1R's in that size all the way around on my LM's. Just wondered if it would work up front or if I just need to try to make a 235/40 work. Thought the 245 may work better since it isn't as tall. TIA
    Got 245/35/17 square.
    Front 8.5x17 ET 15 (-7mm from ap bell = ET8) -2.5cm lowering camber -2.5
    Rear 8.5x17 ET 15 + 10mm spacer -2.5cm
    Sure got to roll the fenders in front and mine rubbed when >3/4 full lock against the plastic cover.
      So you effectively have ET8 offset in the front? dang! Mine are ET18 all around. I ordered the tires and am hoping they will fit without rolling. I'll be putting '96+ control arms up front, treehouse racing FCB's, and AST 4200's with Vorshlag camber plates. Hope to have this setup rockin' and rollin' by the end of next week! The only downsize I see of ordering this size tire is that there are only two companies making this size. At least the R1R seems to be a decent performance tire.
        This is a 245/35/17 8.5*17 "ET8" in front.
          Is 7mm the thickness of the bell minus the thickness of the standard disc?
          Jake
            Jake
            The AP bell is 7mm wider than stock.
            Fits stock 16inches with 304mm 4pots setup, if you want to use stock rims.
              Thanks for the photos and clarification. I'm hoping with my mods I won't have to do much in the department of rolling or dealing with rubbing. I'll know soon enough though.
                Justin, do you have any updates? I have the BBS LM106 from VAC that are 17" x 8.5 et18, so it seems that we're in the same boat size-wise.
                I'm on the fence and considering 225/45/17 for the front and 235/45/17 for the rear. A 215 in the front is too stretched for my taste. I just want to know if other folks are experiencing any rubbing or if it's safe to go with a 245/40 in the rear and a 235/40 in the front without going crazy with the camber adjustments.
                I'm currently running a GC suspension with about -2 degrees of camber up front. The rear camber is negative as well, but I don't know what the current read is.
                I'm looking at the Michelin Pilot Super Sports from Tire Rack.
                http://www.tirerack.com/tires/tires....Qty=2&i1_Qty=2
                Alles Beste!
                B. Wheaton
                Register your E30 M3!
                http://www.bmwmregistry.com
                  Pilot super sports are amazing
                  i had pilot sport 2 on my 08 m3 and they were great
                  but for my 2012 m3 I switched from the OEM 19s of the competition package to 18s in pss
                  and they are noticeably better than the ps2s
                  add to that they they are cheaper, and it's a win/win
                    235/40 17s fit just fine on my setup. Some rubbing at full lock but otherwise no issues.
                    Several E30 M3's.
                      Thanks for the reply, buddy. Are you running a stock suspension or some other combo?
                      Alles Beste!
                      B. Wheaton
                        sorry, i'm not a mechanic.....what is the AP Bell?
                        i'm also interested in fitting 245/35 to my bbs rs 8.5x17 et13 up front. i have camber plates and fenders already rolled while lowered on h&r sports.
                        so you lowered 2.5cm, cambered -2.5 degrees, folled fender, and removed plastic cover and now you have zero rubbing?
                        JAMES
                          The black coloured section in the middle of the disk in the picture above.
                          Schwarz 1990 Sport Evolution
                            Without plastic cover you have no rubbing.
                            But you can adjust the plastic cover a little bit with a 'heat' gun and reshape it, then you'll have no rubbing.
                            Only got a litle bit rubbing with plastic cover @ full lock (with stock plastic cover).
                              Brandon,
                              Sorry I missed these posts. I hate not having the emails to alert replies to threads! I'm still having rubbing issues up front and a little in the back. I know the back will be an easy fix with a slight roll. On the front I need to change the control arms back and see what the rubbing is like with the wheel back in the stock location. The reality is that I should be trying to figure out how to make a 235/40/17 work. There just are not many options for a 245/35/17.
